PIX 515 - CA config not synced to failover unit?
Jun 23, 2005 2 Replies
Waqas
hiii this is because u have create a seperate identity certificate for the other pix firewall. two devices can not have the same single certificate. so u have to manually enroll the other pix firewall with MS CA.
Hi, Cisco wizards!
Subject says it: I have a HA/failover pair running 6.3.4.
I connected the PIX to an MS CA on Win2K server.
ca identity ca configure ca authenticate ca enroll
Everything went as expected, VPN clients can connect.
Then we had a failover - seems like "write standby" does not sync the firewall and CA certificate?
Is this documented somewhere? Should I just enroll both systems with the CA?
Thanks, Patrick
hiii
OK. That's what I figured anyway.
I just wanted to add that seemingly you can't enroll the firewall that is currently in passive mode. So you have to enroll the active firewall, force a failover, then enroll the second node.
Just in case somebody else faces the same problem.
Thanks for your help. Patrick
