Cant view https with zone alarm on
Sep 05, 2005 3 Replies
Jump to replies (3)
After updating ZA , Any https site wont connect - DNS/Server not found.
Have tried adding to trusted sites, changing privacy settings , lowering security settings , repairing winsock, - nothing works but turning ZA off when connecting to https sites. When ZA is turned off it works fine and once connected I can turn ZA back on and continue using the SSL site. But then if I open a new broswer on a secure site with ZA on it fails. Wierd.
Any ideas? Thanks.
Check in at the ZoneLabs Forums, where there is information concerning the last update. Apparently, the upgrade is causing problems when overinstalling instead of a clean install. Links below.
charlie R
snipped-for-privacy@ntu.ac.uk wrote in news:1125912000.294196.192170 @o13g2000cwo.googlegroups.com:
The fact that you turned it off is a NO NO and it doesn't take much to compromise a machine exposed to the Internet like that with a machine that has a direct connection to the Internet, especially with the MS NT based O/S that presents vulnerable services that are not protected.
That's the risk you take with any 3rd party solution like ZA that needs the O/S to function.
Maybe, you should consider putting the machine behind the protection of a cheap $20 NAT router that won't interfere like that. You can then drop ZA at will and the machine will not be compromised because nothing is there to protect it.
Duane :)
Your solution:
That's ok.
"Remove Zonealarm from your PC. You don't need it. Use the Windows-Firewall." (from: , posted 23h before)
To understand some more, have a look at:
HTH Wolfgang
