Can't connect via vpn-1 from home network to work
Mar 11, 2005 3 Replies
Jump to replies (3)
hi,
At home i have a simple home network with two XPs : one is connected to the internet by cables and the second is connected thru the first. i'm using zonealarm pro.
The network at work is protected by Checkpoint's firewall. i tried to install vpn-1 securemote on the second computer ant it appear to connect but failed to find computers on the local network at work.
When i tried to install vpn-1 on the computer that is directly connected to the internet then the second computer disconnected from the internet.
Any ideas ?
Tia
benny
Do you have any rules missing on the firewall? Check the logs and look for denies when you were trying to browse that network.
