blocking tcp port 1050 in sweex modem
Jul 19, 2007 4 Replies
Jump to replies (4)
Why go to one site? There are other sites, and they do return different results. I don't know I could rely on just one site telling me anything.
If the router has a so called DMZ, then port forward the port to a dummy IP in the DMZ so that you can pass the test. If it doesn't have a DMZ, then use a PFW to just block the unsolicited packets that may come to the port on the router and to the port on the pc.
However, if nothing is listening on the port, like a program which most likely nothing is using that port, then it's kind worthless that you even do anything about it.
auditmypc gave the same result.
this port is open according to shieldsup,how can i block this is in my sweex mo250 modem/router? blocking this in my paspersky internet security prog does not work. tried to dig through the manual but have no idea how to do this..
OK, that's your first problem: This result is totally unreliable. Get a serious online port scan like
RTFM and configure it accordingly
For obvious reasons. But one should wonder why you're playing with baby toys..
Firmware update? Return for a found? Letting someone else RTFM as well.
