Bridged LAN
Jan 24, 2006 2 Replies
The question is regarding Repeaters and Bridges.
Both Repeaters and Bridges introduce delays on an Ethernet Network. Brigdes just dont forward un-necessary packets to all the connected segments (besides other things).
What I want to know is, suppose, a "repeater R" and a "bridge B" introduce the same amount of delay on a LAN. Then, will the maximum distance between any two nodes on a LAN constructed using the repeater (R), be the same, compared to, the one constructed using the brigde (B)? Or, can this vary because of the segmenting properties of a Bridge...
Can you point me to a link which describes "What can be the maximum length of a LAN, based on a Bridge?"
Regards, ~ Jagmeet ~
Yes - although repeaters are a few bit times, but most bridges store and forward complete packets.
they dont.
i think you are missing something basic - bridges connect ethernets together, repeater connect cable segments within a single ethernet.
since bridges store and forward packets, a good bridge (i.e. with a low internal processing delay), used to connect low traffic LANs, will have a delay that increases with the length of packet being forwarded
there isnt one - see above. Some bridge functions such as spanning tree impose limits, but they are in terms of the number of bridges across a path - if you need the source then try the
site - i think you need 802.1D
FWIW i have bridged a set of "LAN"s across a WAN a long time ago between US and UK
Hi Stephen
I am concluding from your reply that a bridge connects two different Ethernets together, and therefore it creates different Collision Domains on its either end. It certainly introduces delay due to store&forward but this does not limit its length.
This answers my query.
Thankx, ~ Jagmeet ~
