1152a1x poe
Nov 03, 2004 0 Replies
All, I am checking the 1152A1X. I can check each port by using a powered IP telephone. I need to test both console ports. I can get a link on the cat 5 port but do not have an IP address to ping it I can type characters on the serial port but can not find software to select power levels of each port or assign an IP address to the cat 5 port. What must I do to accumplish the above problem.
Thanks in advance...
