xmodem fail,stuck after transferring
May 18, 2010 0 Replies
It's a Cisco 3620 router with 16M*4 DRAM,16MB+8MB Flash SIMM
Boot: PCMCIA Slot1: No Card Present
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Copyright (c) 1999 by cisco Systems, Inc. C3600 processor with 65536 Kbytes of main memory Main memory is configured to 32 bit mode with parity disabled
device does not contain a valid magic number boot: cannot open "flash:" boot: cannot determine first file name on device "flash:"
rommon 1 > xmodem -c c3620-ik9o3s6-mz.123-26.bin Do not start the sending program yet... device does not contain a valid magic number dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost! Invoke this application only for disaster recovery. Do you wish to continue? y/n [n]: y Ready to receive file c3620-ik9o3s6-mz.123-26.bin ... C
after transfer is complete,nothing shows up so I restart the router
(previous xmodem doesn't work out)
PCMCIA Slot0: No Card Present
rommon 2 > xmodem -c c3620-ik9o3s7-mz.123-22.bin Do not start the sending program yet... device does not contain a valid magic number dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost! Invoke this application only for disaster recovery. Do you wish to continue? y/n [n]: y Ready to receive file c3620-ik9o3s7-mz.123-22.bin ... Erasing flash at 0x317c0000 program flash location 0x30310000
then stuck here ,I restart it
rommon 2 > dir flash: File size Checksum File name 15120140 bytes (0xe6b70c) 0x7f2e c3620-ik9o3s7-mz.123-22.bin (bad checksu m: 0x5bd5)
c3620-ik9o3s6-mz.123-26.bin is 16.3MB and c3620-ik9o3s7-mz.123-22.bin is 14.4MB ,and I have one 8MB and one 16MB Flash SIMM installed.Will it work this way?or something else is wrong?
my last try with only one 16MB SIMM,still stuck after transferring rommon 2 > xmodem -c c3620-ik9o3s7-mz.123-22.bin Do not start the sending program yet... File size Checksum File name 15120140 bytes (0xe6b70c) 0x7f2e c3620-ik9o3s7-mz.123-22.bin (bad checksu m: 0x5bd5)
WARNING: All existing data in flash will be lost! Invoke this application only for disaster recovery. Do you wish to continue? y/n [n]: y Ready to receive file c3620-ik9o3s7-mz.123-22.bin ... Erasing flash at 0x30fc0000 program flash location 0x30660000
stuck
Thanks
