Without Crossover Cable
Sep 26, 2006 5 Replies
Jump to replies (5)
I have a two switches catalyst 2950 and 1 cut-trough cable.
I want to connect the two switches with a 1 cut-trough cable What is the command in the switch for change the 568a in 568b especification ?
its posible?
Regards!
You can't do this without the flux-capacitor up-converter. look on ebay for a flux capacitor.
The 2950 does not do this.
You will need a crossover cable.
If you are desperate (as I was recently) you can make one that works at 10M bps by cutting the cable and twisting the wires together. My 3m cable worked.
The 2950 does not do this? ....So which model does something like this? How?
IT is not entirely clear wht the original poster was looking for but it appeared to me that he was wanting to conect two switches without using a crossover cable,
Many of the more recently released Cisco equipment supports auto-mdix.
Just check the web site for specifics but if I recall correctly
2560, 3560, 3750, 837, 857, 877, various cards for 4500, all do auto-mdix if it is enabled. In many cases it is off by factory default.
catalyst 1900. can do....
Sarastra Maya ha escrito:
