WIC-1ENET in a 1720?
Mar 25, 2005 3 Replies
RobO
Hi Scott According to the document link below (Table 1-4) it only mentions the 1721, 1751 and 1760 routers as supported for the WIC-1ENET......havent looked into it any further. < >As far as I am aware it does'nt matter which slot is used. Hope this helps, Rob
WIC-1ENET in a 1720? open original image
I have a WIC-1ENET card that I'd like to use in my 1720, It does not seem to recognize it. )-;
It sees the WIC-T1 card just fine... Does it matter whcih WIC slot its in?
Thanks, Scott
Hi Scott
Hope this helps,
Rob
~ I have a WIC-1ENET card that I'd like to use in my 1720, It does not ~ seem to recognize it. )-; ~ ~ It sees the WIC-T1 card just fine... Does it matter whcih WIC slot its ~ in? ~ ~ Thanks, ~ Scott
Perfect. Updated Firmware and all is good!
Thanks!
Thanks, Scott >
