Connected to DSL PPPOE, Cant Ping from Outside Interface, Inside OK
Mar 26, 2005 0 Replies
I have a 1721 router with a WIC-1ENET card that I have connected to a DSL Modem. The WIC-1ENET port is configured with a Dialer to do the PPPoE. The Built in is hard coded IP.
I then have a VPN connection back to HQ PIX.
If I ping and source the port to the Built in I can ping just fine. If i ping without specifying a port it does not ping.
This is a problem as I'm trying to save the Config to a TFTP Server on the other side of the VPN. I cant seem to source the TFTP Copy from the Internal port.
Any Suggestions?
Thanks, Scott
