which router for InterVLAN routing ?
Aug 16, 2005 2 Replies
www.BradReese.Com
Hi Mitch, You may wish to investigate the Cisco 1700 Series Configuring Routing Among VLANs with IEEE 802.1Q Encapsulation: Cisco 1751 Configuring Routing Between VLANs with IEEE 802.1Q Encapsulation: Concepts for the Cisco 1700 Router: Cisco 1700 Series Solution Design Tool…
which router for InterVLAN routing ? open original image
hiya,
I've got a half dozen 2950T-24 switches and I want to segment our network into 8 or 9 vlans. Whats the best/cheapest way to go? (our network won't be getting any larger)
This article is close to what I'd like to do but the only feature we are looking for is the InterVLAN 802.1q routing. Is there a cheaper option than the 2600 series?
Thanks Mitch
Hi Mitch,
The Cisco 1751 Configuring Routing Between VLANs with IEEE 802.1Q Encapsulation:
Networking Concepts for the Cisco 1700 Router:
The Cisco 1700 Series Solution Design Tool:
List Prices and Inventory Availability of SMARTnet Eligible Cisco Factory Refurbished 1700 Series Routers:
Sincerely,
Brad Reese Free Cisco Security Upgrades:
Thats Great Brad.
Thanks for the info.
Mitch
