WebVPN missing on Cisco PIX 515 7.1.2?
Apr 19, 2006 1 Replies
Erik Tamminga
Hi, To my knowledge WebVPN is only supported on the ASA series. I know they seem share the same OS base but they do certainly not share the same feature base. Erik
I'm running Cisco PIX 515 7.1.2 software, but i cannot enable web vpn, what is wrong?
thank in advance, Antonio
Cisco PIX Security Appliance Software Version 7.1(2) Device Manager Version 5.1(2)
Compiled on Tue 14-Mar-06 17:00 by dalecki System image file is "flash:/image.bin" Config file at boot was "startup-config"
01-gw up 11 days 6 hours
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz Flash E28F128J3 @ 0xfff00000, 16MB BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1) 0: Ext: Ethernet0 : address is 0011.2094.1dfd, irq 10 1: Ext: Ethernet1 : address is 0011.2094.1dff, irq 11 2: Ext: Ethernet2 : address is 000d.88ee.b394, irq 11 3: Ext: Ethernet3 : address is 000d.88ee.b395, irq 10 4: Ext: Ethernet4 : address is 000d.88ee.b396, irq 9 5: Ext: Ethernet5 : address is 000d.88ee.b397, irq 5
Licensed features for this platform: Maximum Physical Interfaces : 6 Maximum VLANs : 25 Inside Hosts : Unlimited Failover : Active/Active VPN-DES : Enabled VPN-3DES-AES : Enabled Cut-through Proxy : Enabled Guards : Enabled URL Filtering : Enabled Security Contexts : 2 GTP/GPRS : Disabled VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
Serial Number: xxxxxx Running Activation Key: xxxxxxxxxxxxxxxxxx
Configuration last modified by enable_15 at 19:17:27.161 CEDT Wed Apr
19 2006
01-gw(config)# webvpn ^ ERROR: % Invalid input detected at '^' marker.
01-gw(config)#
Erik
