PIX questions.
Jun 26, 2006 3 Replies
Jump to replies (3)
PIX questions. open original image
Going to sell a PIX by second hand and with the following features
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Cisco PIX Firewall Version 6.3(5) Cisco PIX Device Manager Version 3.0(4)
[CUT]
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz Flash E28F128J3 @ 0x300, 16MB BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: ethernet0: address is 0016.465e.0b5c, irq 10 [CUT]
5: ethernet5: address is 000d.887a.1a67, irq 5 Licensed Features: Failover: Enabled VPN-DES: Enabled VPN-3DES-AES: Disabled Maximum Physical Interfaces: 6 Maximum Interfaces: 10 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Unlimited IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Running Activation Key: XXXXXXXXXXXXXXXXXXXXXXXXXXXxx
How much could I ask for it?
If the buyer wants to upgrade to finess 7.x does he need to enter a new Activation key? The PIX doesn't have any 3DES-AES VPN accelerator card. Which is the spare number?
TIA
Alex.
Hi Alex,
Cisco Part Number:
PIX-VPN-515-3DES
Description:
Cisco PIX 515E 3DES/AES VPN/SSH/SSL Encryption License
Cisco Part Number:
PIX-VAC-PLUS
Description:
Cisco VPN Acceleration Card+ for Cisco PIX Security Appliances
You may wish to investigate List Pricing of Refurbished Cisco PIX units that are Fully Licensed and SMARTnet Eligible with Warranties Same as New:
To compare Cisco PIX 515E prices on eBay:
Keep in mind that your Cisco PIX software license is NOT transferable:
Sincerely,
Brad Reese BradReese.Com - Cisco Network Engineer Directory
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
That's obsolete and no longer available.
To get the encryption key, you fill out the form on one of cisco's web pages, and they email it to you for free -- provided you are eligible for it at all.
I've lost track of the eligibility requirements. Alex is in Italy, which appears to be one of the countries whose nationals are permitted under ITAR to receive encryption licenses -- but it does not appear to me [in a few minutes search] that the same is true for all European countries, so Alex would have potential issues in exporting a PIX with the AES license key. Legally safer to not install the key and let the new owner get the key if they wanted (after, that is, Relicensing the device....)
The 3DES-AES VPN accelerator card spare part number:
PIX-VAC-PLUS=
Description:
PIX 66-MHz DES/3DES/AES VPN Accelerator Card+ (VAC+)
List Price:
$3,750
eBay Pricing:
Sincerely,
Brad Reese Cisco Repair
