VTP Traps Generation
Aug 14, 2006 2 Replies
VTP Traps Generation open original image
Hi all,
"VTP Traps Generation" is disabled in my catalyst 2960. How can i enable it ?
Can you please explain for what this option is used ?
Thanks a lot
Best Regards Rahan
Hi Rahan,
VTP Traps Generation:
Status on whether VTP trap generation mode is enabled or disabled.
VTP trap is disabled by default.
If you enable this feature, it causes an SNMP message to be generated every time a new VTP message is sent.
Hope this helps.
Brad Reese BradReese.Com - Cisco CraigsList Job Openings
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Technical Forums
" a écrit dans le message de news: snipped-for-privacy@i3g2000cwc.googlegroups.com...
Thanks a lot Brad !!!
Great !!!
Best Regards Rahan
