Flow Control and traffic optimization
Aug 04, 2006 0 Replies
I use catalyst 2950 and when i run : start int , i can see :
input flow-control is unsupported output flow-control is unsupported
In this case, what happen if "flow control" is enabled on NIC interface of the workstation connected to the switch ?
Is it possible to say that if the interface of the switch don't use Flow Control so i need to disabled it on the workstation ?
Thank You very much
Best Regards Rahan
