VPN Security
Mar 02, 2007 1 Replies
We have several VPN's from remote sites to HQ. Once the VPN is up is there a way to limit traffic in either direction so say only we can see the remote site, and they can only see machines/services our side if we chose to let them.
Is it simpy a case of altering the access lists for what traverses the VPN.
Gary
you have not specified what device you are using, but with the PIX 6.X and lower you would remove the command "sysopt connection permit-ipsec" Then define ACL's accordingly.
