ASA 5505 Configuration Problems
Apr 10, 2008 8 Replies
Jump to replies (8)
I am trying to configure an ASA 5505 to allow Remote Desktop Protocol from outside to a host on the inside network. I created a Security Policy and a Static NAT Rule. But it does not work. Here is my configuration. Any suggestions would be appreciated. This is my first experience with a Cisco security device. I used the ASDM to configure the ASA 5505.
Thanks
sh run
: Saved
ASA Version 7.2(3)
hostname nurm
domain-name mydomain.com
enable password X7L14fUbqxvIsSKn encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.1.1.20 255.0.0.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name orthodyne.de
object-group service nurem_services_udp udp
description port_forwarding_nurem_udp
port-object range 3389 3389
access-list outside_access_in extended permit udp any object-group nurem_services_udp host 192.168.1.2 object-group nurem_services_udp
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (outside,inside) 192.168.1.2 10.1.1.20 netmask 255.255.255.255
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:ff8b7826af792853aa7af84742245a7f
: end
nurm#
You have created the NAT statement, but you now need to create an ACL to allow packets to the host.
access-list outside_access_in extended permit tcp any host 10.1.1.20 eq 3389
In the access-list you could probably also use:
access-list outside_access_in permit tcp any interface eq 3380
I don't know if it matters, but you did not 'switchport' vlan 1 against any ports, the way you did vlan 2. And do you really want the outside interface to be a tagged vlan?
That would only work if both the source and destination port as 3389. Possible for udp -- but on the other hand the last time I checked, RDP was TCP, not UDP, and for the TCP case, you would *not* want to restrict the source port to 3389.
Also, in an ACL being applied to the outside interface, the destination IP needs to be the IP *before de-nat*, the public IP. Like the other poster indicated, you probably want 'interface' there instead of 'host 192.168.1.2' . You might need to use 'interface outside' -- at least that's what you would need for PIX 6.2/6.3
Still doesn't work. I must be missing something.
^^^ that should read eq 3389
can you post the contents of sh access-list and sh nat ...
=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 ^^^ that should read= eq 3389
sh access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max
4096) alert-interval 300 access-list outside_access_in; 1 elements access-list outside_access_in line 1 extended permit tcp any host 10.1.1.20 eq 3 389 (hitcnt=3D0) 0x2b9d88ad
sh nat
NAT policies on Interface inside: match ip inside any inside any dynamic translation to pool 1 (No matching global) translate_hits =3D 0, untranslate_hits =3D 0 match ip inside any outside any dynamic translation to pool 1 (10.1.1.20 [Interface PAT]) translate_hits =3D 0, untranslate_hits =3D 0 match ip inside any _internal_loopback any dynamic translation to pool 1 (No matching global) translate_hits =3D 0, untranslate_hits =3D 0
NAT policies on Interface outside: match ip outside host 10.1.1.20 inside any static translation to 192.168.1.2 translate_hits =3D 0, untranslate_hits =3D 0
You cannot static your entire outside interface to the inside. When you are dealing with your outside interface, static only the ports you need.
You have likely also reversed the order of the interfaces for the static.
Thirdly, you need to use the keyword 'interface' instead of the outside IP address.
Fourthly (if I recall correctly) you are attempting to configure RDP on UDP, but RDP is a TCP protocol. With UDP it might make sense to lock the source port to 3389 but with TCP it does not.
static (inside,outside) tcp interface 3389 192.168.1.2 3389 netmask
255.255.255.255
access-list outside_access_in extended permit tcp any interface outside eq 3389
Walter,
Thanks for the help. I had messed up my config, so I reset the ASA to factory default, did a basic configuration using the setup wizard, then used your commands to configure NAT and the ACL and it worked just fine.
Do I need to make a service group to allow other services such as smtp, pop3 etc or just add lines to my ACL and NAT entries?
Thanks again.
Either way works fine.
The time we started creating object groups was when we started doing mass blocking of problematic IP source addresses. Updating them one by one in the config was a pain, but updating the object group was fairly easy.
Eventually we started using object groups extensively, which was in the context of an PIX configuration generator that I wrote that allowed me to create configuration templates and couple of small host-specific files, and use the templates to generate
*consistant* configurations for all of our PIX. When you start working with meshes of PIXes, you really want to stop dealing in individual IP addresses and instead deal in named groups.
