asa 5540 configuration help
Nov 15, 2007 1 Replies
Hi together,
I need to configure the Asa to route between 2 Interfaces without NAT.
Here my Config, but it doesn't work...i can't get from the inside to the outside interface... Can somebody help???
interface GigabitEthernet0/0 nameif outside security-level 0 ip address xxx.xx.1.201 255.255.255.0
interface GigabitEthernet0/1 nameif inside security-level 15 ip address xxx.xx.201.1 255.255.255.0
interface Management0/0 nameif management security-level 100 ip address 192.168.1.1 255.255.255.0 management-only
ftp mode passive access-list outside_access_in extended permit tcp any any access-list inside_access_out extended permit tcp any any
pager lines 24 logging enable logging asdm informational mtu management 1500 mtu outside 1500 mtu inside 1500 no failover monitor-interface management monitor-interface outside monitor-interface inside asdm image disk0:/asdm-507.bin no asdm history enable arp timeout 14400
route outside 0.0.0.0 0.0.0.0 139.14.1.20 1
timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute http server enable http 192.168.1.0 255.255.255.0 management no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 192.168.1.2-192.168.1.254 management dhcpd lease 3600 dhcpd ping_timeout 50 dhcpd enable management ! class-map inspection_default match default-inspection-traffic ! ! policy-map global_policy class inspection_default inspect dns maximum-length 512 inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp ! service-policy global_policy global Cryptochecksum:85c09f8018db75817b329421456b2806 : end
Hi together,
I need help to configure an ASA. I want to route 2 Interfaces without NAT. But i didn't get from the inside interface to the outside interfac.
Here my config... Can somebody help??
interface GigabitEthernet0/0 nameif outside security-level 0 ip address xxx.xx.1.100 255.255.255.0 ! interface GigabitEthernet0/1 nameif inside security-level 15 ip address xxx.xx.200.1 255.255.255.0 !
! interface Management0/0 nameif management security-level 100 ip address 192.168.1.1 255.255.255.0 management-only ! passwd xx encrypted ftp mode passive access-list outside_access_in extended permit tcp any any access-list inside_access_out extended permit tcp any any pager lines 24 logging enable logging asdm informational mtu management 1500 mtu outside 1500 mtu inside 1500 no failover monitor-interface management monitor-interface outside monitor-interface inside asdm image disk0:/asdm-507.bin no asdm history enable arp timeout 14400
route outside 0.0.0.0 0.0.0.0 xxx.xx.1.20 1
