ASA 5505 problem with smtp
May 05, 2008 0 Replies
I can=B4t get any email through my asa, can anybody help me. My config:
ASA Version 7.2(1) ! hostname ciscoasa domain-name default.domain.invalid enable password jQUCdrURwbTfANCO encrypted names ! interface Vlan1 nameif inside security-level 100 ip address 192.168.27.1 255.255.255.0 ! interface Vlan2 nameif outside security-level 0 ip address x.x.x.118 255.255.255.252 ! interface Vlan3 no forward interface Vlan1 nameif dmz security-level 50 no ip address ! interface Ethernet0/0 switchport access vlan 2 no nameif no security-level no ip address ! interface Ethernet0/1 no nameif no security-level no ip address ! interface Ethernet0/2 no nameif no security-level no ip address ! interface Ethernet0/3 no nameif no security-level no ip address ! interface Ethernet0/4 no nameif no security-level no ip address ! interface Ethernet0/5 no nameif no security-level no ip address ! interface Ethernet0/6 no nameif no security-level no ip address ! interface Ethernet0/7 no nameif no security-level no ip address ! passwd 2KFQnbNIdI.2KYOU encrypted ftp mode passive dns server-group DefaultDNS domain-name default.domain.invalid access-list outside_access_in extended permit tcp any interface outside eq smtp pager lines 24 logging enable logging asdm informational mtu outside 1500 mtu inside 1500 mtu dmz 1500 asdm image disk0:/asdm-521.bin no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 static (inside,outside) tcp interface smtp 192.168.27.5 smtp netmask
255.255.255.255 route outside 0.0.0.0 0.0.0.0 x.x.x.117 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00 timeout uauth 0:05:00 absolute http server enable http 192.168.27.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd auto_config outside ! dhcpd address 192.168.27.2-192.168.27.129 inside !
! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp ! service-policy global_policy global prompt hostname context Cryptochecksum:a378936e1a5a804b1de047ee9b80b998 : end [OK]
