Natting Outside to Inside with Port Access
Jan 18, 2008 2 Replies
Hi I have had a request to allow PCAnywhere in froman external address.
Can somebody give me some help?
ip nat inside 192.168.1.2 outside 82.69.*.* TCP 5631 ip nat inside 192.168.1.2 outside 82.69.*.* UDP 5632
Do i need and acces list too?
Here is what i have already:
no ip http server no ip http secure-server ip nat inside source route-map FOR_NAT interface Dialer0 overload ip nat inside source static tcp 192.168.1.3 6129 interface Dialer0
6129 ip nat inside source static tcp 192.168.1.3 3389 interface Dialer0
3389
Cheers,
Ry,
You shouldn't need an ACL since you're limiting the translation to just those ports. Have you labbed it up to test though? It's always a good idea to run an idea through a lab before implementing.
neteng
I'm going to give this a try tomoz and see if it works.
ip nat inside source static tcp 192.168.1.2 5631 82.69.26.154 5631 extendable ip nat inside source static udp 192.168.1.2 5632 82.69.26.154 5632 extendable
If not any more help would be great!
Thanks,
Ryan
