Help with Cisco ASA 5505 config for BellSouth DSL
Aug 08, 2007 0 Replies
Hello all, I just purchased a Cisco ASA 5505 and I am having trouble configuring my device to work with my BellSouth DSL connection. I tried placing the Netopia 3347NWG in what's called bridge mode but then configure the 5505 for PPPOE but authentication continued to fail. Now I am going to try PPPoE with a Routed Subnet, using the instructions from the Netopia link below
I am including my current 5505 conf for your viewing. Any help or advice would be greatly appreciated.
-JT-
hostname JASZLINK-5505 domain-name jaszlink.net enable password xxxxx encrypted names name 10.1.1.200 DC01 description Doman Controller name 10.1.1.206 Dev01 description Development Server name 10.1.1.202 Exchange01 description Exchange Server name 10.1.1.204 Project01 description Project Server ! interface Vlan1 description Inside Network Interface nameif inside/LAN security-level 100 ip address 10.1.1.1 255.255.255.0 ! interface Vlan2 description Outside Network Interface nameif outside/WAN security-level 0 ip address 72.151.92.106 255.255.255.248 ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 ! interface Ethernet0/2 ! interface Ethernet0/3 ! interface Ethernet0/4 ! interface Ethernet0/5 ! interface Ethernet0/6 ! interface Ethernet0/7 ! passwd 2KFQnbNIdI.2KYOU encrypted ftp mode passive clock timezone EST -5 clock summer-time EDT recurring dns server-group DefaultDNS domain-name jaszlink.net same-security-traffic permit inter-interface same-security-traffic permit intra-interface access-list inbound extended permit tcp any host Exchange01 eq smtp access-list inbound extended permit tcp any host DC01 eq 3389 access-list inbound extended permit tcp any host DC01 eq pptp access-list inbound extended permit tcp any host Dev01 eq 5904 pager lines 24 logging enable logging asdm informational mtu inside/LAN 1500 mtu outside/WAN 1500 ip verify reverse-path interface outside/WAN no failover icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-522.bin no asdm history enable arp timeout 14400 nat (inside/LAN) 1 10.1.1.0 255.255.255.0 static (inside/LAN,outside/WAN) 72.151.92.107 DC01 netmask
255.255.255.255 static (inside/LAN,outside/WAN) 72.151.92.108 Exchange01 netmask
255.255.255.255 static (inside/LAN,outside/WAN) 72.151.92.110 Dev01 netmask
255.255.255.255 static (inside/LAN,outside/WAN) 72.151.92.109 Project01 netmask
255.255.255.255 access-group inbound in interface outside/WAN timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00 timeout uauth 0:05:00 absolute http server enable http 10.1.1.0 255.255.255.0 inside/LAN no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd update dns ! dhcpd address 10.1.1.x-10.1.1.x inside/LAN dhcpd dns 10.1.1.1 interface inside/LAN dhcpd enable inside/LAN ! dhcpd dns 205.152.37.23 205.152.132.23 interface outside/WAN !
! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp
prompt hostname context Cryptochecksum:xxxxx : end
