VPN Concentrator 3020 problem with Voip
Mar 09, 2007 0 Replies
Hello, I just need a few hints from any of you experts. USign skype on VPN connection makes it unusable. Audio becomes a junk and you can hear only noises. THis happens using a VPN connection with whatever version of Cisco VPN client to my Cisco Concnetrator 3020. If the VPN is not used this problem does not occour. Anyone had this problem ? THis happens both using UDP vpn and also TCP.
thanks
Rick
