VPDN and IP local pool
May 23, 2005 0 Replies
Hi all
I have on my C1760 an interface virtual-template and a VPDN-group to allow pptp users to "vpn" my site.
I use on the interface Virtual-Template1 the command:
peer default ip address pool POOLNAME
linked to the pool:
ip local pool POOLNAME 192.168.57.1 192.168.57.254
and everything works fine.
My trouble is that I would like to assign to a specific remote user a fixed IP address and do not know how to do it.
If I configure the vpn client with fixed address for instance
192.168.57.254, it does not take the configured value but a different one of the pool range.
The authentication and accounting is performed by a MS IAS Server. If I tell IAS Server to assign to this specific ppp user/pass an address, would it work ? I think that the PPP LCP ( or was it PPP CCP) is not relayed to the IAS Server...
Is there a way to assign the user a specific IP address , managing it on my C1760?
Regards
Jaime
