VOIP at home (not Cisco related)
Dec 01, 2005 2 Replies
Hello,
I am having problem with VOIP at home. I do have Vonage service which I access thru my cable modem. Here is the situation:
Old apartment: Only broadband connection (no cable TV) - Voice is clear
New apartment: Broadband connection + cable TV - Voice calls (and even dial tone) have some TV/music in the background (faint sounds but audible)
How do I correct this problem? Are there any devices that will clean up the IP stream? Yesterday I did not hear much sound but my girlfriend at the other end could hear music. Is there anyway to clean up the outbound VOIP connection?
I know this is not a Cisco issue but I did not know where else to turn for help. Thank you in advance for any help or advice.
Regards,
Hi Subba,
It sounds like your analog phone picks a radio signal or has too sensitive microphone. It's a small chance also that your VoIP box (adapter) picks that signal. It has nothing to do with VoIP itself - it's all straight bytes and bits, and if IP packet is corrupted or missing, you will have gaps in the speach, but not a music. Try to get another analog phone, and, if possible, get another VoIP adapter to try.
Good luck,
Mike
You may wish to investigate the Vonage User Forum:
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
