HOME VOIP-PSTN
Sep 21, 2005 3 Replies
Jump to replies (3)
HOME VOIP-PSTN open original image
Hi I would like to make my computer a VOIP device (via software) and have a server that has a Modem dial out for me. When the phone rings, the modem will receive the ring pulse and if the computer is on, it can then "ring" for me. I cannot find any solutions that do this without some special hardware or corporate devices. Or is there a device that hooks into my network and to the phoneline and does this function already that I can buy? If so ideas are greatly apreciated!!!
Asterisk could be your best bet
BTW you will need to a QuickNet LineJack as a full-duplex sound and modem card or some generic card supported by asterisk...
Please cnsider the following switch and interconnection hub. extra universal io jacks 100% surge protected, too!
COMBINE-A-LINE .. Imagine..1=2
Ever wish you could use your favorite single-line telephone, answering machine, caller ID or PC Modem on TWO phone lines?.. Automatically?
OR
How about joining your VOIP port and the plain old (PSTN) telephone jack into a single handset?
OR
How about joining TWO VOIP ports into a single handset, answering machine, caller ID or PC Modem?
USE a CLT to join a card card acceptor and your single line telephone as well!
OR
see if anybody picks-up, on another line trunk, after you are already in a call??? A visual real-time security feedback feature!
THEN...........................................
Combine-A-Line (CLT) allows two separate calls from two different lines to be directed to your single line telephone equipment or PC. Centralizing and PROTECTING (SURGE PROTECTION INSIDE) your communication equipment for your home office or for the family.
Combine-A-Line supports all services from your telephone company including Caller ID. It also has two line surge protectors to make sure that you are Protecting your equipment.
Use combine-aline to automatically switch between VOIP and pots (rboc) plain local line, hands free!.
SECURITY of your calls are enhanced because the CLT displays if anybody picks -up the line after you are in a call! So, it has security features just in case someone is wire tapping or listens in after you are in a call. The LED display will indicate any disruption to the line.
Easy to use, No batteries or power supply, and no programming needed! Our re-sellers have reported that ..."elimination of the noisy and cumbersome power supply wires, reduces the Hum & Noise one hears then when connected to household power supplies"
Automate and organize your telecommunications equipment and desktop wires with Combine-A-Line.
USE BUY NOW and get FREE SHIPPING OPTION
WOW FREE SHIPPING!
Add a second CLT to your auction win for only $14.42.
Reduced shipping on second unit... only $3.42 ... wow reduced shipping
Link to instructional video
Answers from previous customers:
A: this unit has many uses. it can combine two analog (regular plain Jane telephone lines) into a common point. This allows you to create a dual line telephone suite(telephone, answering. modem) etc for way less than the cost of a two line phone and two line answering machines and modems don't commonly exist. Further, VOIP has become very popular and users gain tremendous long distance rates rates, however they don't have a "local presence" and often back up the voip with a single plain Jane telephone line. the clt will join voip and telco to a signal automatic port for the ultimate convience! Plus no power supply or batteries to clutter your desktop! Plus all port surge protected to protect you equipment! plus two additional universal (I/O) line 1 and line 2 dedicated ports... enabling an even wider array of connection schemes.
A: S&H outside CONUSA (48 USA states) costs more. The tariff diferene varies based on exact location. The range is about $1.00 to Canda and Mexico, and Hawaii. And is $3.00 to most of EU and Middle eastern locations.
A: In coming activity is automatically routed to the auto output port.
A: Out bound activity is automatic. Users can mnaully re-direct any cal and visually confirm which line is in use by observing the LED indication.
A: The unit can be wired into a single telephone jack with the lines (four wire connectors) OR there are two additonal , inversal jacks that enable physical connnections to different phone access port. For example line 1 on a VOIP modem and line2 to your local Telco jack. The CLT can join any two lines and provide a single convient access point.
A: The CLT does not require batteries or wall power supplies.
Uhhh, yeah, I think I bought one of those at Radio Shack about FIFTEEN YEARS AGO. Cutting-edge technology, there.
