VAC or VAC+ on a Pix running 7.x
Feb 13, 2006 3 Replies
Jump to replies (3)
How do I determine (remotely) if I'm running a VAC or a VAC+ in a Pix running 7.x code? "show crypto interface" apparently doesn't work in
7.x code.
Thanks J
Try "show crypto accelerator statistics" and look at the end of the display for hardware related info.
I don't see anything related to hardware in the output so I'm guessing that this 525 doesn't have a VAC or a VAC+ installed.
MDF-FLR2-FW1# show crypto accelerator statistics
Crypto Accelerator Status
------------------------- [Capability] Supports hardware crypto: True Supports modular hardware crypto: True Max accelerators: 2 Max crypto throughput: 100 Mbps Max crypto connections: 3000 [Global Statistics] Number of active accelerators: 0 Number of non-operational accelerators: 0 Input packets: 40 Input bytes: 11560 Output packets: 565569 Output error packets: 0 Output bytes: 80620272
[Accelerator 0] Status: OK Software crypto engine Slot: 0 Active time: 128993 seconds Total crypto transforms: 1134507 Total dropped packets: 0 [Input statistics] Input packets: 40 Input bytes: 11560 Input hashed packets: 40 Input hashed bytes: 7128 Decrypted packets: 40 Decrypted bytes: 11560 [Output statistics] Output packets: 565579 Output bad packets: 0 Output bytes: 80621600 Output hashed packets: 565579 Output hashed bytes: 89638368 Encrypted packets: 565579 Encrypted bytes: 80621600 [Diffie-Hellman statistics] Keys generated: 47 Secret keys derived: 94 [RSA statistics] Keys generated: 0 Signatures: 0 Verifications: 0 Encrypted packets: 0 Encrypted bytes: 0 Decrypted packets: 0 Decrypted bytes: 0 [DSA statistics] Keys generated: 0 Signatures: 0 Verifications: 0 [SSL statistics] Outbound records: 0 Inbound records: 0 [RNG statistics] Random number requests: 281 Random number request failures: 0
Thanks for the info. J
