Using SSH
May 20, 2005 5 Replies
Jump to replies (5)
Hi all,
Is it possible to use SSH to manage routers and switches with IOS IP only ?
Thank You very much
Best Regards NS
In article , ns wrote: :Is it possible to use SSH to manage routers and switches with IOS IP only ?
Some, but not generally. There is often a distinct image that one has to load that has ssh support.
Your article-id suggests that you are in France. Since Cisco is a "foreign company" as far as France is concerned, would Cisco have to provide an ssh "back door" in order to satisfy the laws in France about foreign corporations being required to give their encryption keys to France ?
ThankYou Walter for your answer.
i dont's understand your question about encryption in France. in France, the encryption is denied but not in this case...
Cdly NS
"Walter Robers> :Is it possible to use SSH to manage routers and switches with IOS IP only ?
I have two routers with 12.2(7r) IPBase image and they do not show the option SSH for "transport input".
Another router with AdvanceIPServicek9 shows me that option.
So I guess the IP image does not provide ssh connection.
DT
Thanks a lot DT
Cdly NS
a écrit dans le message de news: snipped-for-privacy@g14g2000cwa.googlegroups.com...
IANAL, but it seems that there are no key-escrow type restrictions for importing devices running SSH to France.
However, export regulations of the USA subject SSH to special scrutiny, which is why SSH is only available in K9 classified images.
Check out
"France used to have strong restrictions on import and domestic use of encryption products, but the most substantial restrictions were abolished in early 1999. Export regulations are pursuant to the Wassenaar Arrangement and controlled by Service Central de la Sécurité des Systèmes d'Information (SCSSI)."
Seems there was a big hulabaloo in 1997, but cooler heads prevailed.
