Filter and log big ip packet
May 16, 2005 6 Replies
Jump to replies (6)
Hi all,
Can you tell me how can i filter and log a big ip packet on the routers ?
It seem not possible with access-list ! Other way ?
Thank You very much for your precious help
Best Regards NS
PBR with a match on size, and forward it to null0
Jonathan
ThankYou Jonathan for your answer
I will try to learn more how it's can be configured with policy basic routing
Thanks a lot NS
"Jonathan" a écrit dans le message de news: snipped-for-privacy@news3.newsguy.com...
It is pretty simple...
Route-Map [name] permit match length [min length] [max length] set interface null0
The problem here is that it will not log the PBR...
Jonathan
Oh, yeah, you also need to apply it to an interface...
int fa0/0 ip policy route-map [name]
Jonathan
Does this configuration infect performance of router ?
Thanks a lot Jonathan
Best Regards NS
Any time you analyze packets, you are going to affect performance.
How much you affect performance is impossible to calculate...
You basically need to do it, and see what happens.
Jonathan
