Good day All. Has anyone had an issue with the Ctrl-Break with the new USB Db9 ....since LAptop companies seenm to think that this is obsolete ....How can we circumvent this, ....I am looking for some anwers on how to do a Ctrl-Break on Cisco boxes and others ...with USB-DB9 conversion . Thanks all in adavdnce
USB to DB9 Ctrl-Break ?
May 17, 2005
I have used a few USB->COM converter from different brands and they all work as you were using a normal COM port. i.e. you press "Ctrl+Shift+6, x". hktco ....How
Read the full replyI have used a few USB->COM converter from different brands and they all work as you were using a normal COM port. i.e. you press "Ctrl+Shift+6, x".
hktco
baffm> Good day All.
....How
Which laptops and OS?
The only issue I've run into, is that the Mac OSX driver for the PT2303 chip (used many places for those $30 USB->Serial IOGear convertors) doesn't support sending break. You need a keyspan device to properly do break on a Mac OSX laptop.
Otherwise, the windows driver for that chip works for break (although the windows driver has other issues) as well as the keyspan driver on windows.
Good day Thanks for the post The suspend a Telnet session, enter the escape sequence Ctrl,Shift,6 X option is not what I am seeking. I am seeking an actual ctrl-Break to enter #rommon mode ....... Thanks again
snipped-for-privacy@hotmail.com wrote:
If you're using hyperTerminal, make sure it is configured to send "CTRL" characters and not use them for Windows. This unfortunately will prevent you from doing CTRL-X,C,V for cut & paste, but I've never had any problems with sending CTRL-BREAK through a USB-DB9 adaptor.
Same. It works by pressing "Ctrl+Brea". Not sure which Terminal program you are using, but you can try TeraTerm Pro and there is an option to "Send Break" in the menu.
hktco
baffm> Good day
"Ctrl+Shift+6,
Are you sure you are using the right break key combinations. Here is a helpful link I think
I have an USB-DB9 converter for my HP laptop, for both hyperterminal and CRT it's business as usual...
Cas..
