Sup2 2Ge MSFC2 power and fan requirements ?
Feb 15, 2006 6 Replies
genki
The show ipprom fan-tray command does not exist. B6509m1> (enable) show ver WS-C6509 Software, Version NmpSW: 7.6(12) Copyright (c) 1995-2005 by Cisco Systems NMP S/W compiled on May 4 2005, 14:59:23 System Bootstrap Version: 5.3(1) System Boot Image File is 'bootflash:' System…
Sup2 2Ge MSFC2 power and fan requirements ? open original image
Hi, I cannot for the life of me find any documentation for the power and fan requirements for the Sup2. MSFC2 module for the 6509 chassis.
Can anyone tell me if I will need to upgrade fan or power modules if I upgrade the following system,
Can anyone tell me how I can tell which fan module I have installed please ?
Thanks !
System Bootstrap Version: 5.3(1) System Boot Image File is 'bootflash:cat6000-supk8.7-6-12.bin' System Configuration register is 0x2102
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA0537024G
PS1 Module: WS-CAC-1300W Serial #: SNI05110634 PS2 Module: WS-CAC-1300W Serial #: SON05040531
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD05340296 Hw : 7.0 Fw : 5.3(1) Fw1: 5.4(2) Sw : 7.6(12) Sw1: 7.6(12) WS-F6K-PFC SAD0533089D Hw : 1.1 Sw : WS-X6K-SUP1A-2GE SAD05340296 Hw : 7.0 Sw :
2 2 WS-X6K-SUP1A-2GE SAD0534021T Hw : 7.0 Fw : 5.3(1) Fw1: 5.4(2) Sw : 7.6(12) Sw1: 7.6(12) WS-F6K-PFC SAD053308AH Hw : 1.1 Sw : WS-X6K-SUP1A-2GE SAD0534021T Hw : 7.0 Sw :
3 8 WS-X6408A-GBIC SAL0535AY9Y Hw : 2.0 Fw : 5.4(2) Sw : 7.6(12)
4 48 WS-X6348-RJ-45 SAL0534AVEX Hw : 5.0 Fw : 5.4(2) Sw : 7.6(12)
6 48 WS-X6348-RJ-45 SAL062720W1 Hw : 6.1 Fw : 5.4(2) Sw : 7.6(12)
9 3 WS-SVC-NAM-1 SAD09290ADS Hw : 3.0 Fw : 7.2(1) Fw1: 7.2(1) Sw : 3.4(1a) Sw1: 7.6(12)
Most like by the looks of your configuration you have a WS-C6K-9SLOTFAN.
Merv, you are the man, this is what I get with a show prom fan, I still
can't exactly see which fan it is.
B6509m1> (enable) show sprom fan Common block: Block Signature : 0xabab Block Version : 1 Block Length : 144 Block Checksum : 0xf6a EEPROM Size : 256 Block Count : 2 FRU Major Type : 0xab03 FRU Minor Type : 0x1 OEM String : Cisco Systems Product Number : WS-C6000-CL Serial Number : SMT0507K280 Part Number : 73-4013-01 Part Revision : A0 Mfg Deviation : H/W Version : 1.0 Mfg Bits : 0 Engineer Use : 0 snmpOID : 9.5.1.2.18.1.2.2 Power Consump : 0 RMA Code : 0-0-0-0
FRU-specific block: Block Signature : 0xab03 Block Version : 1 Block Length : 24 Block Checksum : 0xc9 Feature Bits : 0x0 HW Changes Bits : 0x0 Stackmib OID : 2 Cooling Capacity: 0 Ambient Temp : 0
Thanks for all you help
D
for sup2 msfc2 power and heat info see:
