Strange errors in cisco 3845
Dec 26, 2006 3 Replies
Jump to replies (3)
Doing a 'sh log', i see this:
Dec 26 15:24:17.676: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78' Dec 26 15:24:17.680: %SYS-3-MEMLITE: Free lite called for non lite chunk by '0x6146BA78'
Any ideas?
My hardware & version info:
fw3800(config)# do sh ver Cisco IOS Software, 3800 Software (C3845-ADVSECURITYK9-M), Version
12.4(9)T, RELEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2006 by Cisco Systems, Inc. Compiled Sat 17-Jun-06 00:59 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
Cisco 3845 (revision 1.0) with 221184K/40960K bytes of memory. Processor board ID FHK0904F10S
16 FastEthernet interfaces
2 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco ids sensor(s), ids monitoring on slot 2 DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x2102
Probably a bug. May or may not affect operation. Try reload ... does it come back? Try power off/on ... does it come back?
Do you neet the "T" train. You should not use it if you don't need it.
12.4(3)g (if I recall correctly) is General Deployment. Suggest you start there if it supports your hardware and required features.
open a case with the Cisco TAC
you could also try upgrading to newer release
12.4.11T (ED) 12.4.9T2 (ED) 12.4.9T1 (ED)
You are hitting DDTS CSCse60965 and this bug is purely cosmetic, therefore there is no performance impact on this router at all.
A potential workaround which was mentioned in the DDTS is to disable ACLs but this is untested and I wouldn't recommend it either way.
You have two options, either live with this DDTS or ask TAC for the interim build 12.4(10.5)T or upgrade to 12.4(11)T or above sticking to the T train until 12.5(x) is out.
They might fix it in the EDs and GDs for train 12.4(x) but there is no guarantee.
R
