SSL Module - config-register
Dec 03, 2005 0 Replies
silly question, can't google it out or find on cisco web site.
Can You give me a hint, what is a command to set a config-register on SSL Module. There is no config-register command in config mode and I need it for reload command. SSL MODULE is in 6509 chasis right now.
SSL#reload in 30 Reload to the ROM monitor disallowed from a telnet line. Set the configuration register boot bits to be non-zero.
tia
