Software recovery for Aironet AP1120B
Jun 08, 2006 2 Replies
Software recovery for Aironet AP1120B open original image
Hi, I was wondering if anyone knew how to get an Aironet AP1120B up and running again when it fails to boot. I upgraded the software and it successfully booted the first time, then i screwed up the configuration and pressed the "reset" button to remove the config and start again now the AP doesn't boot anymore. Since there is no console port I'm a bit lost, is there really no way to recover from this?
-SAto
You may wish to investigate Cisco Aironet 1100 Series Troubleshooting.
Reloading the Access Point Image
Hope this helps.
Brad Reese BradReese.Com - Cisco Network Engineer Directory
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
BradReese.Com=AE - Leverage Your Cisco Network skrev:
It sure did, thanks!
I've been searching for this but came up blank. (at first I was blind, but now I can see) Thought there had to be a way to do this, and as it turns out there was.
Thanks again!
-SAto
