Cisco 1841 Config Problems with BT Broadband
Jan 25, 2007 8 Replies
Jump to replies (8)
I'm setting up a different 1841 for another client with the following config and it just doesn't want to Connect - I've been looking at it so long the last hour or two, that I can't see the wood for the trees....
Internet/Dialer Config is as follows:
interface ATM0/0/0 no ip address no atm ilmi-keepalive dsl operating-mode auto pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 !
interface Dialer0 ip address negotiated ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer idle-timeout 0 dialer persistent dialer-group 1 no cdp enable ppp authentication chap ppp chap hostname yyyyyyy ppp chap password 0 xxxxx !
ip route 0.0.0.0 0.0.0.0 Dialer0
the DSL signal locks (or at least the LED on the unit tells me it does).... The Following Debug Information May Help:
debug atm events
*Jan 25 12:44:13.887: ATM0/0/0 check_lockup: scc = 0, output_qcount =
0, head:(s )110, 110, addr = (s)0x0, 0x0, count (s)110, 110
*Jan 25 12:44:13.887: ATM0/0/0 check_lockup: scc = 1, output_qcount =
0, head:(s )55, 55, addr = (s)0x0, 0x0, count (s)55, 55
*Jan 25 12:44:23.871: ATM0/0/0 check_lockup: scc = 0, output_qcount =
*Jan 25 12:44:23.871: ATM0/0/0 check_lockup: scc = 1, output_qcount =
*Jan 25 12:44:29.203: ATM0/0/0 dslsar_tx_status_ind(64C19A9C). vcd: 5 NOT IN USE , Status=932505, tStamp: 82B725.
*Jan 25 12:44:29.231: ATM(ATM0/0/0): vci 0, vpi 0, index 0 is incorrect
*Jan 25 12:44:31.239: ATM(ATM0/0/0): vci 0, vpi 0, index 0 is incorrect
*Jan 25 12:44:33.243: ATM(ATM0/0/0): vci 0, vpi 0, index 0 is incorrect
*Jan 25 12:44:33.799: ATM0/0/0 check_lockup: scc = 0, output_qcount =
0, head:(s )110, 113, addr = (s)0x0, 0x0, count (s)110, 113
*Jan 25 12:44:33.799: ATM0/0/0 check_lockup: scc = 1, output_qcount =
0, head:(s )55, 55,
debug ppp negotation / debug ppp authentication
*Jan 25 12:45:19.379: Vi2 LCP: TIMEout: State Listen
Jan 25 12:45:19.379: Vi2 PPP: Authorization required
*Jan 25 12:45:19.379: Vi2 LCP: O CONFREQ [Listen] id 121 len 15
Jan 25 12:45:19.379: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:19.379: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:21.395: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:21.395: Vi2 LCP: O CONFREQ [REQsent] id 122 len 15
Jan 25 12:45:21.395: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:21.395: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:23.411: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:23.411: Vi2 LCP: O CONFREQ [REQsent] id 123 len 15
Jan 25 12:45:23.411: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:23.411: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:25.427: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:25.427: Vi2 LCP: O CONFREQ [REQsent] id 124 len 15
Jan 25 12:45:25.427: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:25.427: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:27.443: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:27.443: Vi2 LCP: O CONFREQ [REQsent] id 125 len 15
Jan 25 12:45:27.443: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:27.443: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:29.459: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:29.459: Vi2 LCP: O CONFREQ [REQsent] id 126 len 15
Jan 25 12:45:29.459: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:29.459: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:31.475: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:31.475: Vi2 LCP: O CONFREQ [REQsent] id 127 len 15
Jan 25 12:45:31.475: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:31.475: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:33.491: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:33.491: Vi2 LCP: O CONFREQ [REQsent] id 128 len 15
Jan 25 12:45:33.491: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:33.491: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:35.507: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:35.507: Vi2 LCP: O CONFREQ [REQsent] id 129 len 15
Jan 25 12:45:35.507: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:35.507: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:37.523: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:37.523: Vi2 LCP: O CONFREQ [REQsent] id 130 len 15
Jan 25 12:45:37.523: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 25 12:45:37.523: Vi2 LCP: MagicNumber 0x19611144 (0x050619611144)
Jan 25 12:45:39.539: Vi2 LCP: TIMEout: State REQsent
*Jan 25 12:45:39.539: Vi2 LCP: State is Listen
Anyone point me in the right direction please?
Cheers,
C.
Post the "sh dsl int atm 0/0/0" output.
Alex.
I'm not sure, but you might want to change the line under dialer0 for the authentication to be
ppp authentication chap callin
so it's one-way authentication instead of attempting two-way.
However, if you're not even seeing BT's PE router then that's not your first issue - which would be 'does the adsl train up?' Post a 'sh dsl int atm 0/0/0' as at the moment your debug doesn't show any incoming LCP messages...
Does the bb work with another router? Is there dial-tone on the line (connected directly to the line & through the filter)?
Hi Alex,
Thanks for the message - here's the output of sh dsl int atm0/0/0
Alcatel 20150 chipset information ATU-R (DS) ATU-C (US) Modem Status: Showtime (DMTDSL_SHOWTIME) DSL Mode: ITU G.992.1 (G.DMT) Annex A ITU STD NUM: 0x01 0x1 Vendor ID: 'ALCB' 'TSTC' Vendor Specific: 0x0000 0x0000 Vendor Country: 0x00 0xB5 Capacity Used: 93% 59% Noise Margin: 6.5 dB 21.0 dB Output Power: 20.0 dBm 12.0 dBm Attenuation: 25.5 dB 14.0 dB Defect Status: None None Last Fail Code: None Selftest Result: 0x00 Subfunction: 0x15 Interrupts: 2651 (0 spurious) PHY Access Err: 0 Activations: 1 LED Status: ON LED On Time: 100 LED Off Time: 100 Init FW: embedded Operation FW: embedded SW Version: 3.8131 FW Version: 0x1A04
Interleave Fast Interleave Fast Speed (kbps): 8096 0 448 0 Cells: 11 0 63962749 0 Reed-Solomon EC: 184 0 8 6 CRC Errors: 150 0 6 4 Header Errors: 146 0 3 4 Bit Errors: 0 0 BER Valid sec: 0 0 BER Invalid sec: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 4 3 5 7 7 7 8 7 8 10: 7 8 8 8 7 7 7 8 7 7 6 6 5 5 0 0 20: 0 0 0 0 0 0 8 8 9 9 A B B C C C 30: D D D D D D D D D D D D D D D D 40: 0 D D D D D D D D D D D D D D D 50: D D D D D D D D D D D D D D D 2 60: D D D D D D D D D D C D D D D D 70: D D D D D D D C D C C C D C C C 80: C C C C C C C C C C C C C C C C 90: C C C C C C C C C C C C C B C C A0: B B C C B C B B B B B B B B A B B0: B A B B B B B A B A B B B B B A C0: A A A A A A A 9 9 9 9 9 9 9 9 9 D0: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 E0: 9 8 9 9 9 9 9 8 8 9 9 9 8 8 8 8 F0: 6 6 5 4 3 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
Hi Al,
Thanks for the message... I've changed it to ppp chap callin, however my debug comes up with this line:
*Jan 26 10:47:03.255: Vi2 DDR: Dialer statechange to up *Jan 26 10:47:03.259: Vi2 PPP: Using dialer call direction *Jan 26 10:47:03.263: Vi2 PPP: Treating connection as a callout *Jan 26 10:47:03.263: Vi2 PPP: Session handle[95000003] Session id[1] *Jan 26 10:47:03.263: Vi2 PPP: Phase is ESTABLISHING, Active Open *Jan 26 10:47:03.263: Vi2 PPP: Authorization required *Jan 26 10:47:03.263: Vi2 PPP: No remote authentication for call-out
What does this mean?
Rgds,
C.
I have no knowledge of your actual hardware/software. Some residential DSL modems will scan a variety of known VCI/VPIs to see if they can reach someone. But some do not.
If your router/modem does not scan all available VCI/VPI to find a host at the other end, you need to configure it with the right VCI/VPI numbers.
With invalid VCI/VPI, your modem will obtain Sync at the DSL levels. Howver, the ATM frames get sent to unkown ATM destination and go into a big bit bucket.
These numbers vary from telco to telco. So you need to get BT to reveal to you what their VCI/VPI values would be.
This tells the modem to whom it should send the ATM frames. And when you have the right values, your ATM frames blindly get sent to the BT regional basic access server (glorified router which reroutes ATM packets to the ISP)
Also, in yor other message, you had a Signal to Noise ratio of 6.5 on the
8mbps side of the line. This probably explains why you are on interleave. Below 6 is not recommended, 6 to 10 is marginal.
0,38 are the values used on my BT and Zen ADSL lines.
Yes - you are right... however, I have set my VCI/VPI in the Interface Settings as per:
snip...
I have enlcosed a config of a typical ADSL config I would drop onto a router using a BT line:
interface ATM0 (change as applicable for your ATM slot no) bandwidth 288 no ip address no atm ilmi-keepalive pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto
interface Dialer0 description Connection to XYZ ip address negotiated ip nat outside ip access-group outside in (your access-list - change as applicable) encapsulation ppp dialer pool 1 ppp authentication chap callin ppp chap hostname snipped-for-privacy@btinternet.com ppp chap password YOURPASWORD
The above should be fine.
Regards
Darren
