sdm on xp pro
Dec 10, 2006 6 Replies
Jump to replies (6)
has anyone tried running SDM successfully in Xp pro. So far I could only run from w2k Pro. maybe to some extent in xp if I log in as administrator w2k offers more robust operation.
oh, btw, what does install a copy on device do? would that actually let me run SDM from device via https?
Its very sensative to the version of the JVM installed on the machine. I'd imagine you are running too new a version on your XP box for its liking.
The JAR files are stored on the router instead of on the workstation. Makes it more convienient if you have the large FLASH space required since you don't have to have SDM installed on multiple machines if you move around some. You'd still run into JVM version issues though.
as a regular xp user?
I am using the same JVM on Xp and w2k jvm 1.4.2-06-b03
where can I get 1.5.0 build 1.5.0_06-b05 they now have build 1.5.0_09-b03
which does not work for me.
I also tired on Xp Version 5.1.2600 sp2: 2600.xpsp_sp2_gdr.50301-1519 Service Pack 2 I kept on getting activex blocked and have to click to let go. this occurs despite I put the file:\\\\\\c:\\cisco\\sdm as trusted, inactivated firewall
what build of XP Pro are your using?
