Routing based on destination IP address
Nov 13, 2006 2 Replies
Hi All,
I need to configure some static routes like this in order to implement a work like load balancing :
route outside 155.195.65.23 255.255.255.255 IP_ROUTER_1 route outside 155.195.0.0 255.255.0.0 IP_ROUTER_2
Anyone know if is it works?
Thanks Daniele
Sure, of course. Simple routing. The difficult part is going to be your source address on your ASA or Pix and routing back to it.
This will not do any balancing because destinations are not the same. When you want balance traffic, then both prefix and mask has to be the same, else only best match will be used.
Cheers, iLya
