OSI encapsulation over IP network
Nov 13, 2006 3 Replies
OSI encapsulation over IP network open original image
Hi there.
Have two sites connected by 1700 series routers using ADSL for wan connection. Need to get OSI traffic from one site to the other site. Can anybody point me in the right direction to enable any OSI traffic to be encapsulated and broadcast ( effectively ) to the other site. Or, possibly setup two 1700 series routers ( ADSL WAN interface ) to just act as bridges to other sites thus extending the broadcast domain.
Many thanks
Pete
Pete Matthews MCSE BSc(Hons)
If bridging is ok for you, then perhaps DLSW+ or remote source-route translational bridging (translate to token-ring at ingress then back to ethernet at egress) are suitable for your scenario. Have a look at
. For routed solution have a look at IS-IS - it's native for OSI/DECnet.
Cheers, iLya
I am pretty certain that you can configure the OSI protocols and IP on the same interfaces and use say ISIS for dynamic routing.
I would try that first before looking at tunneling if I could.
It does look as if you can do CLNS over GRE. That would be my plan B if the MTU was not a problem?
You can also route IP and bridge everything else.
IIRC this looks like
int eth 1 ip address x.x.x.x bridge-group 1
int eth 2 ip address x.x.x.y bridge-group 1
ISO-CLNS
the only problem is that next-hop is likely DSL provider, which will through away everything except appropriate IP traffic, so you'll have to do tunneling between sites and GRE tunnels can't be assigned to a bridge group. That's why you'd need either DLSW+ or remote source-route translational bridging if you want to bridge across IP cloud.
/iLya
