policy based routing
Nov 04, 2005 14 Replies
Jump to replies (14)
Setup:
T1 Cable Modem | | | | |-----------------------------------| | S0/0 Fa0/1 | |172.16.10.30 192.168.10.10 | | | | Cisco 2621 | | | | | | Fa0/0 10.10.10.8 | |-----------------------------------| | |
Internal Network
Everything routes out of the T1 currently. I was assigned a dynamic reserved address from the cable modem. So I get the following information from the ISP of the cable modem, I am able to ping the default gateway and see the packet count go up by that number of packets on the Fa0/1 interface, so I know the added directly connected route is working:
IP Address: 192.168.10.10 Subnet Mask: 255.255.255.0 Def. Gateway: 192.168.10.1
I tried the following Policy-Based Routing setup and thought this would work, but I must have something wrong somewhere. I only want to send HTTP traffic out the cable modem for now, then figure out other steps later. With this PBR in place, all traffic to websites stop, everything else continues to function.
Changes to Config:
access-list 131 permit tcp any any eq www
route-map Websurfers permit 45 match ip address 131 set ip next-hop 192.168.10.1
(interface Fa0/0) ip policy route-map Websurfers ip route-cache policy
Can anyone see an issue with this, or where I may have made a mistake?
Thanks,
Scott
What about your NAT configuration?
Greg
No NAT until you get behind the firewall protecting the internal network.
I also tried in the route-map section setting "set interface FastEthernet0/1" instead of the "set ip next-hop".
The problem is that you're sending this traffic out with 10.10.10.x source addresses, but the cable ISP is probably configured only to route
192.168.10.10 back to your connection. You need to enable NAT on the router so that traffic going out fa0/1 will be translated to this address.
hmmm..
would it be something as simple as, ip nat inside on the fa0/0 interface and ip nat outside on the fa0/1 interface?
would this screw up my already working routing of fa0/0 to s0/0 by default?
thanks,
scott
You also need to configure a NAT pool that translates to the outside interface's IP.
No. If there's no "ip nat outside" on s0/0, then any traffic routed out this interface will be unaffected by NAT.
Okay, I think I'm going down the right track. Here are the changes that I added to my config:
Fa0/0
------- ip nat inside
Fa0/1
------- ip nat outside
General Config
---------------- ip nat inside source route-map Websurfers interface FastEthernet0/1 overload
It didn't seem to work, but wouldn't this essentially be what I am looking for instead of an access-list based nat pool? since I'm looking to only send policy-based traffic out that interface with the cable modem attached?
Thanks again,
Scott
Hi
Is it possible to route traffic from one interface only to routes that are advertised to the router with BGP protocol? For example supose that "sh ip route" output is like this:
B 1.1.1.0/24 [200/1] via 4.4.4.4, 1d20h B 2.2.2.0/24 [200/1] via 4.4.4.4, 4d15h B 3.3.3.0/24 [200/0] via 4.4.4.4, 3d21h S* 0.0.0.0/0 [1/0] via 5.5.5.5
What I would like to set up is, if the client on interface FE0/0 wants to go to networks 1.1.1.0/24, 2.2.2.0/24, 3.3.3.0/24 his traffic would be routed. But if he tries to go somewhere else (destination network is in this case 0.0.0.0) the packets would be dropped.
What kind of match rule should I use???
Thanks for help
Igor
You can't use a match in this way, but if you reverse your logic you could remove the default and use 'set ip default next-hop' on interfaces that are allowed to use it to achieve the same end result.
Andy
Something along the lines of: ! route-map TEST permit 10 match ip address 101 set interface Null0 ! access-list 101 deny ip 1.1.1.0 0.0.0.255 access-list 101 deny ip 2.2.2.0 0.0.0.255 access-list 101 deny ip 3.3.3.0 0.0.0.255 access-list 101 permit ip any ! interface FastEthernet0/0 ip policy route-map TEST ! HTH Cheers Alex
If the default route is removed it will affect ALL users on the box, not only those who come from Fa0/0. HTH Cheers Alex
I can't do this because those networks could change. And there is much more networks not only three as I showed in the example. The networks are learnd from another box. So I need to set up something like this on my router:
If you want to go to routes I learnd with BGP you are allowed. If you want to go somewhere else your packets would be dropped.
Igor
Hence the use of PBR and 'set ip default next-hop x.x.x.x' for all other interfaces that need to use the default... It's an ass-backwards kludge, but I can't see any way of doing it that doesn't involve hard-coding BGP prefixes into the PBR policy-map (which kinda defeats the purpose of using BGP in the first place, I would think)
Andy
You could automate this with script running off UNIX box: script should periodically RSH into the Cisco router in question , get the list of BGP routes then complile/change the access-list. HTH Cheers Alex
Be very careful with just how much you help people as the results may be catastrophic.
