problem with wireless on a Cisco 877W
Mar 05, 2009 3 Replies
Jump to replies (3)
I have a few Cisco 877W routers running IOS 12.4(22)T
Users on this release are reporting constant Wireless LAN failures. The routers will run for a few days and then all wireless devices fail to communicate.
If an XP PC for instance is rebooted that connects via wireless then it will fail to get an IP address.
Rebooting the router fixes the issue for a few days.
This is happening on several 877W's we have.
Has anyone else seen this problem?
Regards
it is a known bug. downgrade or upgrade to the latest .24T (but don't know if it has fixed this bug)
In message , Galerio writes
Do you know a bug reference for it by any chance? If possible I'd like to upgrade as opposed to downgrade, but only if 24T fixes it.
Regards CLive
Clive Carmock ha usato la sua tastiera per scrivere :
Don't know if it is a known-by-cisco bug,but I'm sure that is known by many users. You can always look at Cisco.com where there is a detailed bug list and bug-fixed list for every build.
