problem with IOS
May 29, 2006 2 Replies
hi everybody I have problem with my 2620, I upgraded an IOS version to 12.4.3 and from this point my router on every start decompressing the image. I made all configuration than copy to startup-config but always the same.
here is print when router starts:
Self decompressing the image : ################################################# ################################################################################ ################################################################################ ########################################## [OK]
Smart Init is enabled smart init is sizing iomem ID MEMORY_REQ TYPE
000094 0X000B3B80 C2600 Single Fast Ethernet 0X00098670 public buffer pools 0X00211000 public particle pools TOTAL: 0X0035D1F0
If any of the above Memory Requirements are "UNKNOWN", you may be using an unsupported configuration or there is a software problem and system operation may be compromised. Rounded IOMEM up to: 3Mb. Using 5 percent iomem. [3Mb/64Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (C2600-ENTBASEK9-M), SOFTWARE (fc2) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Fri 22-Jul-05 05:09 by hqluong Image text-base: 0x80008098, data-base: 0x818B8158
Port Statistics for unclassified packets is not turned on.
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to snipped-for-privacy@cisco.com.
Cisco 2620 (MPC860) processor (revision 0x200) with 62091K/3445K bytes of memoryLY 20000 usec,e" counters never20 (MPC860) proce . Processor board ID JAD051009BP (589753981) M860 processor: part number 0, mask 49 software5
1 FastEthernet interface dspu
1 Serial interfacewnStream Physical
1 ISDN Basic Rate interface
32K bytes of NVRAM. Keepalive set (10
16384K bytes of processor board System flash (Read/Write) Modify enable password parametersevererent
Press RETURN to get started!
*Mar 1 00:00:17.255: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state t
*Mar 1 00:00:17.259: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
*Mar 1 00:00:18.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern et0/0, changed state to down
*Mar 1 00:00:18.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to down
*Mar 1 00:00:19.675: %LINK-5-CHANGED: Interface BRI0/0, changed state to admini stratively down
*Mar 1 00:00:20.675: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0, ch anged state to down
*Mar 1 00:00:20.919: %SYS-5-CONFIG_I: Configured from memory by console
Mar 1 00:30:05.583: %LINK-5-CHANGED: Interface Serial0/0, changed state to adm inistratively down
*Mar 1 00:30:06.139: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C2600 Software (C2600-ENTBASEK9-M), Version 12.4(3), RELEASE SOFTWARE (fc2) Technical Support:
*Mar 1 00:30:06.143: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Mar 1 00:30:14.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern et0/0, changed state to up Router>
if you can help me thanks in advance WZ
thats how it works. the router decompress the image because it is compressed into the IOS file. thats how it is with the new IOS's.
and between us , how many times do you need to restart your router ? it should be online ...like always.
WZ schrieb:
The IOS Image needs 128 MB RAM, your router only has 64 MB. The Image is for a 2620XM.
