problem during install vpn client
Mar 23, 2005 2 Replies
i'm trying to install the vpn client on my winxp pc, but the install crashes during "installing the Deterministic Network Enhancer". I receive a return code: 214650093.
I tried two different versions (4.0.5 and 4.6.0), but both give the same error.
Can anybody tell me what's going on and how to resolve this?
Thanks!!! Jouke
Do you have a third party firewall installed? If so, uninstall it, install the VPN client and then reinstall the firewall.
The win-xp installation was almost fresh, with just a view applications installed. There was no 3rd party firewall installed. I uninstalled almost everything and updated win-xp to the latest patches available. The client still wouldn't install. A bit frustrated, I smashed the pc agains the wall, formatted the c-drive and re-intalled win-xp (including sp2). After that the client installed with no problems.........
So the h> Do you have a third party firewall installed? If so, uninstall it, install
