Cisco SSL VPN client setup problem
Oct 29, 2007 1 Replies
I'm trying to implement WebVPN solution using Cisco SSL VPN Client (sslclient-win-1.1.0.154.pkg) on ASA5505 (sw. ver. 7.2(2))... After WebVPN authentication ASA automatically starts with SSL Client setup process, but it fails each time after download is complete with the following error message: "cisco ssl vpn client failed to install and start agent" I tried on both XP and Vista OS. On both PCs user has admin privileges...
Anyone with similar issues?
BR, Igor
You could have a bad .pvc image file, try downloading it again from Cisco.com and deleting the old .pvc image and uploading the new. Also check add/remove programs and see if you have another version of a VPN client software and remove those as well.
