Problem accessing web server
Jul 19, 2005 3 Replies
Jump to replies (3)
Problem accessing web server open original image
Hello
I have a PIX 515E with DMZ, Lan and Wan interfaces.
From my web server or any device in DMZ, I can access to
but I cannot access to
which is hosted by my web server.
Servers in DMZ can ping each other. Static NAT is enabled between DMZ and WAN. My Website can be reached by Internet Users.
I don't understand why from DMZ I cannot access to my web site which is also in DMZ.
If anyone has an idea.
Hi
I agree... I think this is a DNS resolution issue. If the name resolves to the public IP address you may have trouble with the NATing fro inside the DMZ.
Why do you need to resolve the website address from inside the DMZ (Just curious)?
JT
In article , jp wrote: :I have a PIX 515E with DMZ, Lan and Wan interfaces.
:From my web server or any device in DMZ, I can access to
:but I cannot access to
which is hosted by my web :server.
:Servers in DMZ can ping each other. :Static NAT is enabled between DMZ and WAN. :My Website can be reached by Internet Users.
:I don't understand why from DMZ I cannot access to my web site which is :also in DMZ.
Are you using split DNS or the PIX 'alias' command (deprecated), or the 'dns' keyword on your static translations?
When you look up the IP address of
on your web server, do you get the public IP or the private IP as known on your DMZ?
Thanks a lot. I find a solution. I add some lines in the hosts file. There is a batch running on the server and trying to reach the websites. If there is no response, the batch reboots the server.
