Port forwarding ranges of ports in IOS
Aug 25, 2007 1 Replies
Is this possible? For instance, I want to port forward inbound a VoIP providers UDP ports (e.g. 16000 16500). I cannot find anything about how to do this so I'm thinking it's not possible.
Thanks
you can use the 'range' parameter in the access list's command, i.e.: access-list 100 permit udp [source ip_add] [dest ip_add] range 16000
16500
If you are NATing you should issue the related commands.
hope this helps Nikos
