PIX plus RDP on Second Port (not 3389)
Aug 23, 2006 1 Replies
We have a Cisco PIX (501 I am pretty sure) and are using RDP to connect through a static IP address and default port 3389 to a Terminal Server. I would like to use the same IP address and a second/different port to connect to a second Terminal Server. This would require something like port translation or port forwarding. Is this possible? And how?
I have searched quite long and hard several times for an answer and have not found anything. I know on the client RDP side that I would specify the IP/port as xx.xx.xx.xx:yyyy. I also have seen mention that maybe Cisco version 6.33 is necessary.
Thanks for any help, Alan
As the client supports alternate ports, and as RDP is not something that PIX 6 has a "fixup" for, this should be easy on any PIX OS version supported on the PIX 501.
static (inside,outside) tcp interface 3389 FIRSTSERVERIP 3389 netmask
255.255.255.255 static (inside,outside) tcp interface YYYY SECONDSERVERIP 3389 netmask 255.255.255.255
