CISCO PIX 501 and DHCP on outside port
Nov 19, 2007 1 Replies
Hello,
I have an interesting problem I would like to solve and I hope someone her can assist me.
I have a CISCO PIX 501 firewall unit. This particular unit supports giving out DHCP leases on its outside (public) port.
I connected a worksation to the outside subnet and was able to recive a public ip address that I defined on the PIX. The problem I ma encountering is that I cannot specify a gateway - it only provides the ip of the PIX for the gateway.
Does anyone know how I can get the correct (different gateway, not the PIX as a gateway) ip address assigned ?
Thanks,
Mark
snipped-for-privacy@generation.net
"buddd" ha scritto nel messaggio news: snipped-for-privacy@d4g2000prg.googlegroups.com...
As far as I know (pretty little and outdated information about PIXes) there is no way to assign a different gateway (sounds logical since if you were to assign a different gateway for the hosts they would not get "firewalled")
You can always proxy the DHCP requests to another DHCP Server.
Regards, Gabriele
