Port forwarding once again
Oct 03, 2009 0 Replies
Just wanted to add another example of how to set up port forwarding on a cisco asa 5505.
This is how I managed to get it working.
This is an example where the inside network is 192.168.1.0 with netmask 255.255.255.0. The cisco asa has an ip address of 192.168.1.1.
I am doing this by connecting to the ASA with the console cable using the terminal emulator ZOC pro 6.14 from emtec software. bitrate is
9600 8N1.
ciscoasa> ena ciscoasa# conf t
First you set up some NAT rules. This is a rdp rule to a server on the inside net with an ip address of 192.168.1.13
ciscoasa(config)# static (inside,outside) tcp interface 3389
192.168.1.13 3389 netmask 255.255.255.255
Then you can set up a http rule to the same server
ciscoasa(config)# static (inside,outside) tcp interface 80
192.168.1.13 80 netmask 255.255.255.255
Ok we now have two rules, to make them work set up some access rules
ciscoasa(config)# access-list outside_access_in extended permit tcp any any eq 3389 ciscoasa(config)# access-list outside_access_in extended permit tcp any any eq http
Then setup the outbound accesslist rule
ciscoasa(config)# access-list inside_nat0_outbound extended permit ip
192.168.1.0 255.255.255.0 192.168.1.0 255.255.255.0
Then at last set up the exempt NAT rule
ciscoasa(config)# nat (inside) 0 access-list inside_nat0_outbound
Save the configuration
ciscoasa(config)# wr mem
Then do a reload
ciscoasa(config)# reload
I am not saying that this is the correct cisco way to do it, but this is how I got it to work. good luck with your cisco ASA 5505
Dag Kl=E6stad
