PIX configs exactly same on cluster members
Apr 28, 2008 1 Replies
Hi all, I've been asked to look at a Pix cluster that didn't failover properly when the master went down last. One thing I noticed is that although the 'sho ip address' command reveals Current Ip Addresses to be different to each other, both boxes have the same hostname and exactly the same config when you 'show run'
I know that Pix boxes swap MAC and IP addresses on failover but I didn't expect to see the config and hostnames being identical. Is this correct?
The other strange thing is that, although the config is for Active/ Standby (not Active/Active) - no failover groups are configured - 'show ver' reveals the active unit is licenced for Active/Active and the standby as Active/Standby.
Cheers MN
Yes.
That's ok.
You might search for "show failover".
