PIX 515e IOS 7.0(5) and when the Power goes out, the PIX reboots to Boot Monitor
Jan 06, 2009 3 Replies
Jump to replies (3)
I have a PIX 515e IOS 7.0(5) and when the Power goes out, the PIX repoots to Boot Monitor.. I type Reload and its back up and Running.
What can I do to make it jsut boot into the IOS and get running?
Thanks, Scott
just a hint;
do you have the console port permanantly plugged in the serial port of a PC.
I had a situation where both the PC and the PIX would reboot simultaneously, and i guess during the reboot , the PC was sending some kind of garbage on the serial port , causing the PIX to boot in Monitor mode.
Not exactly Scott.
I have followed the Pix Getting Started Guide which uses the ASDM 5.2(4) software, and got it to "work". However I didn't understand the use of IP groups, and thus created a weird configuration that gets me close to what I wanted, but has some problems. I may be able to fix this by starting over. I really want to establish the inside address NATed address range to only appear on the outside (Ethernet0) port address. I also want that address to be a static assignment. I have tried assigning it, and can not find any place to put a gateway address so that it works. I have been able to configure the DNS and of course fail to get outside because of this.
It is my desire to have the pix in a non-routed mode if at all possible.
I have figured out how to make the DMZ port static NAT so that my DNS address pool is a one to one relationship with 5 of my outside addresses. However I haven't been able to ping the outside addresss, only the DMZ. This may be normal. Although it doesn't seem right.
I also don't understand why my higher security ports can't get out to lower ports without a rule being set up. It doesn't make sense. I was under the impression that any higher security level automatically could go to a lower one.
Any comments would be appreciated.
Gracias
David
