Pix 501 VPN and PPPoe
Dec 06, 2007 4 Replies
Jump to replies (4)
The outside interface is connected to dsl modem and PPPoe connection has been configured on Pix 501. Can this pix firewall be configured to accept vpn connections? If yes, is there limitations?
Roman schrieb:
Yes.
The same as with regular IPoE.
Does this include pptp as when I try vpdn enable outside, pix says outside interface is already used by pppoe?
RG schrieb:
Sorry, I can't help you there, I don't use pptp.
PIX OS versions 6.2 and 6.3 do not support Layer 2 Tunneling Protocol (L2TP) and Point-to-Point Tunneling Protocol (PPTP) with PPPoE.
cu ivo
